Unread 05-02-2008, 03:50 PM   #1
kip younger
kip younger has disabled reputation
Default Shift lever very hard to move???
I put a 700r4 in my vette, behind a 350. When installing a B&M shifter, I discovered that the shift lever on the tranny is very hard to move. The new shifter will not move the lever from park and such... Its hard to move by hand also. I know there is nothing wrong with the shifter. So, is there something wrong with the tranny? I've connected the tv cable, made sure the tranny is full of fluid. Still hard to move lever. Help? kip
kip younger is offline   Reply With Quote
Unread 05-03-2008, 10:03 AM   #2
Ms. AntiVenom
Vicious Evil Person
Ms. AntiVenom's Avatar
Ms. AntiVenom will become famous soon enough
Do you have it full of trans fluid? I say that because..... before I met Greg I put a new 700r4 in my 93 and didnt put enough fluid in it (being carefull) and the shifter wouldent move intill I figured it out
also I had to adjust the tv cable
I will ask the big guy when his hands are free for his input (saterdays are nutty here)
allright, he said to check the B&M ****er cable itself, that they need adjustment, they sometimes bind and make it impos. to ****
here is another site
Website
Ms. AntiVenom is offline   Reply With Quote
Unread 05-03-2008, 12:29 PM   #3
Z06 Rocket
Z06 Rocket's Avatar
Z06 Rocket is on a distinguished road
Yea if your bound up that can be a problem.......
Z06 Rocket is offline   Reply With Quote
Unread 05-03-2008, 12:51 PM   #4
Mark Dalton
Mark Dalton has disabled reputation
Yup, a little ex-lax will fix that right up.
Mark Dalton is offline   Reply With Quote
Unread 05-03-2008, 07:48 PM   #5
kip younger
Cool
Do I just drop that ex-lax down the filler tube???????
Pulled the pan off today, found everything OK. Was surprised to see the depth of the notches on the thing that the roller rides over. It's no wonder it takes so much force to get the roller over the notches. I have the tv cable connected, to what looks to be OK, do need to put more fluid in it.
Still having trouble getting the middle carb of a tri carb set up the idle good. Seems to idle too low, too rough... I've checked for vacuum leaks and all that. Its a 2GV, however, and it has no choke system on the carb. It used one from the manifold I've read... So, with out the vacuum system, there is no tension against the idle cam, and the choke butterfly doesn't act right. Any chance of getting a choke system that could go on such a carb? thanks - kip
Get Your Stock C6 Z06 in the 10s - Maximum Acceleration, Part 3 RSS Feed Tech and How-To Articles 0 02-07-2008 05:12 PM
2007 C-6 Automatic w/paddle shift Sweptclean General Corvette Discussions 7 01-14-2008 10:31 PM
Page generated in 0.74955893 seconds with 10 queries
