Unread 03-17-2007, 02:43 PM   #1
"Backyard Mechanic"
"Backyard Mechanic"'s Avatar
"Backyard Mechanic" has disabled reputation
Default Busy Morning
Well this morning I lowered the Vette and Painted the brake calibers. It all seemed to go well,nothing has falling off yet I put 4 coats of paint on each calibers,going to let them dry and see how they look tommorrow,Hopefully I won't have to touch them up.The pictures are in the photo gallery if you would like to check them out. Rob.
"Backyard Mechanic" is offline   Reply With Quote
Unread 03-17-2007, 02:59 PM   #2
Classy
Car Arts Auto Detailing
Classy has disabled reputation
Default O Great
Great, now I can't get over any bumps.I knew I should of stayed home this morning Anyone one to trade husbands?
Classy is offline   Reply With Quote
Unread 03-17-2007, 03:02 PM   #3
"Backyard Mechanic"
Sorry Dear.
Unread 03-17-2007, 05:34 PM   #4
98 softtail
Bug Killer
98 softtail's Avatar
98 softtail will become famous soon enough98 softtail will become famous soon enough
Those Calipers look nice. I have a caliper paint kit sitting on a shelf in my garage, I have been procrastinating on painting mine but yours look good. Now I might have to get busy and paint mine.
Joe B.
98 softtail is offline   Reply With Quote
Unread 03-17-2007, 06:03 PM   #5
chris308
spam sniper
chris308's Avatar
chris308 is on a distinguished road
Did you use an online write-up to do the drop? I have been wanting to lower mine but the fronts aren't really clear from the write ups i have seen.
chris308 is offline   Reply With Quote
Unread 03-17-2007, 07:27 PM   #6
"Backyard Mechanic"
Thanks for the compliments,The paint is easy to do,put you have to have sometime on your hand,you have to put the first coat on and then wait 15-20 mins. Then put the other coats on within a hour or you have to wait a whole day to finish.That's each caliber.So if you do it like I did,one at a time,figure 4 hours.If you can have all the tires off,then you can just go around to each caliber and put a coat on each one then wait,etc.That should only take a hour or so.
I lowered by turning the bolt on the leaf spring,turn it COUNTER CLOCK WISE,until you have two threads left,and that is it. The front,it is easier to take out the bottom bolts out from the shocks.The back you don't have to.Then drive it around and in time it well settle and lower itself,I got about 2 and 1/2 inches ont the front and 2 inches on the back.Hopefully in a week it will go down another 1/2 inch or so.That was actually easier to then the paint. I can't count how many times I took off the tires today.
All in all it was pretty simple and the sterring is just fine,and rides Awesome now.
If you need any help just let my know.Rob
Unread 03-17-2007, 07:45 PM   #7
chris308
spam sniper
chris308's Avatar
If i have this correct, the rears your want less threads showing, and the fronts you want the most threads showing right? Did you cut ant of the bushing up front? I read you can either cut the bushing or remove the bolt completely. Some noises may occur by removing the bolt completely though. Is that your experience as well?
Thanks for the reply Rob, I may do this tomorrow or monday.
Unread 03-17-2007, 08:09 PM   #8
98 softtail
Bug Killer
If I lower my vette I won't be able to drive on most of the roads around here... I was driving along the other day where they are repaving the road and the storm sewer manhole covers were sticking up so far that I cringed everytime I drove over one. I thought for sure that I was going to scrape the bottom of the car.
Unread 03-17-2007, 08:35 PM   #9
"Backyard Mechanic"
Default It is easy,Trust me
Both the front and back bolts will have 2 threads left on them.I did not remove the bolts completly or cut the bushing.I just did'nt feel I wanted it that low.I also have some sh*tty roads here but it seems to take them well.I do have to pull in the driveway a little slower now,Slight dip in the driveway and I scrape the skrits,but no big deal.Rides great and no noise.You can buy alonger bolt for the rear and it will go lower,but i think I'm good for now.If anyone needs a hand,let me know and I'll swing by and help.I did not use Air tools to this,by hand ,only used air tools to take the tires on and off.Hope this helped.
Unread 03-17-2007, 08:45 PM   #10
chris308
spam sniper
chris308's Avatar
thanks for the replies Rob i'm going to check it out tomorrow.
Good morning! 2Vettes General BS forum 5 01-07-2007 06:40 PM
Ran this over this morning... MADN3SS Maintenance, Mods, & Tips 13 11-08-2006 11:09 AM
Good morning from Orlando Larry B. Welcome Room 12 08-10-2006 11:23 PM
Good morning! exile Welcome Room 12 05-08-2006 10:39 AM
Page generated in 0.20143604 seconds with 10 queries
