Unread 10-24-2012, 09:30 PM   #1
Tampa Tuning
Tampa Tuner
Tampa Tuning's Avatar
Tampa Tuning is on a distinguished road
Default Tampa Tuning Saturday dyno tune price specials
From now till December 15th, Tampa Tuning is offering a Saturday dyno tuning out the door price special with the dyno time included.
To dyno tune a Camaro, Corvette, GTO from stock to bolt ons the cost is $350.00
To dyno tune a Camaro, Corvette, GTO with aftermarket internals (cam) $420.00
To dyno tune a Camaro, Corvette, GTO with Forced Induction $500.00
Tampa Tuning will performance:
Read and reprogram your PCMs settings and perform real time scan diagnostics for the best results
Increase power enrichment rate mode
Examine and change timing tables for additional horsepower & torque gain
Optimize your vehicle’s Air and Fuel Ratio monitored with a wideband
Reduction of Intake Air Temperature table (heat soak prevention)
Desired rev limiter adjustments
Park, neutral, and in- gear idle adjustments with and without A/C active as needed
Adjust power enrichment delay
Engine torque management system reduced
Transmission torque management system reduced
Transmission shift points enhanced
Transmission shift times reduced
Transmission shift firmness enhanced
Skip shift deleted (CAGs 1st to 4th shift)
Fuel injector rescaling for aftermarket injectors
Cooling fan activation temperature recalculated
Perform speedometer recalibration for rear gear ratio and tire size change
Turn off check engine light and remove trouble codes
Neutralize rear oxygen sensors that cause CEL
Idle calibration
Start up airflow calibrated
Long Term Fuel Trims dialed in
Open and closed loop calibration for optimized results
Disable Displacement on Demand ( AFM)
...and other performance calibrations to achieve maximum safe results
You can reach me at Tuning@TampaTuning.com
or call 813-727-8720
Burn your tires not your wallet
Phil
Check out TAMPA TUNING on FACEBOOK and INSTAGRAM .
www.TAMPATUNING.com
813-727-8720
Corvette Camaro GTO CTS-v Dyno Charger and Challenger DYNO Tuning in Tampa, Brandon, St. Petersburg, Bradenton
Tampa Tuning is offline   Reply With Quote
Unread 11-18-2012, 06:07 PM   #2
Tampa Tuning
Tampa Tuner
Default Camaro Corvette GTO performance Firebird Truck tuner in Tampa Orlando
I had a couple phone calls last week about if I was tuning on November 24th after Thanksgiving, and yes I will be dyno tuning in St. Petersburg.
Thanks
Phil
Idle calibration
Phil
www.TAMPATUNING.com
813-727-8720
Tampa Tuning dyno tuning of GM Truck Avalanche Silverado Tahoe Colorado Canyon Sierra Tampa Tuning Member to Member Services 1 11-20-2012 01:52 PM
Tampa Tuning still has the best priced tunes Tampa Tuning Performance Tuning 2 05-25-2011 09:08 PM
TUNE............ zzzona Performance Tuning 8 11-28-2010 05:59 PM
Best tuner price Tampa Tuning for Corvette C5 C6 Camaro Gen5 GTO Firebird WS6 TransAm Tampa Tuning Performance Tuning 0 11-11-2010 08:35 AM
Tampa Tuning Torque Management Special $50 Tune Tampa Tuning Performance Tuning 3 11-08-2010 09:44 PM
Page generated in 0.34408402 seconds with 11 queries
