10-11-2007, 12:58 PM
spam sniper
Need a little guidance here. H/C guys pull up a seat!!
Ok, in my ongoing quest for more power, I have decided to take the plunge and do the H/C route and my next endevour...
The goal: I am looking to get around 400+ range out of my LS1 in NA form.
Current mods: TSP LT headers, X-pipe (no cats)
Granetelli catback exhaust
LS6 Intake Mani
Ported TB
So I have been doing some research and have decided to go with Patriot stageII 5.3 heads. Mainly due to the great feed back on them and the cost.
http://www.patriot-performance.com/w...05233&DID=1225
What I need help on is cam specs..... I have zero knowledge on what is a good cam or what will work with the heads i'm looking into.
All I know is 400+ out of the combo, must be tame for daily driving use and still give some power.
What say you....
10-11-2007, 02:15 PM
Vicious Evil Person
If you want to talk about that stuff you can call Greg 813-690-0175 he can give you any Info he is like an encyclopedia.
and FYI trust me wont try to sell you anything He will talk to you like you grew up next door to him.
I cant get him to take time out today to sit at the desk, he is on a mission today and allot big things are happing at the shop.
Website
10-11-2007, 03:01 PM
spam sniper
Thanks Rashelle,
I don't wanna interrupt him with my mega-newbie questions.
I'm in no rush, just throwin out questions here n there and getting some opinions if i could from those that have seen the light and walked the path!! I'm still just in the beginning stages of researching this project of mine.
10-11-2007, 03:03 PM
Vicious Evil Person
Well anytime! I might be able to get him to spout me some numbers to post
Website
10-11-2007, 03:48 PM
A cam and those heads could make you anywhere from 370 rwhp to 440 rwhp. The bigger the cam, if properly selected, the more hp and the worse driveability. The "classic" cam for a setup like that is a 224/228 XE-R with a 114 LSA and a 110 ICL (or "+4"). That cam will make over 400, and with the proper tune will still drive nice, have good low end (although not, perhaps, low-low end), and get good mileage. It will have some lope. If you want something with better driveability, go down 4 degrees to a 220/224/114/110. For more top end, go up 4 degrees to a 228/232/114/110. If, within one of those, you'll trade a rougher idle for more low end, a slightly higher peak number, and a slightly narrower powerband, go to a 112 or even a 110 LSA.
All this assumes a M6 transmission and 3.42 gears. If you have an automatic, you almost have to go to a high-stall torque converter at the same time as you go to a cam, unless it is an extremely mild cam, and the cam and converter should be selected and installed together.
By all means, talk to Greg and have him order up a cam for your specific needs. He will grill you on questions like where you want the idle, how rough an idle, how much lope, where you want the powerband, how you normally drive, future mod plans, etc., etc. The desired rwhp is almost not even a factor. We all want as much power as we can get *within the other parameters we're willing to live with*, and those are what drive the cam selection. RWHP is just a number on a piece of paper, you can't drive it.
Atomic Tiger Z06:
First production 2009 Z06 off the line, Buyer's Tour 6/20-23/08, Museum Delivery 7/14/08, PBC tour 7/23/08.
427 LSX/WCCH/ARH/Callies/Oliver/Diamond/Morel/232/256/630/F1-A/Dallas/797rwhp/11psi/pump gas
BC3/Quicktime/DSS/Pfadt/Carbotech/Quantum/Muffler Mod/PS2 ZPs, Atomic Orange, Dark Titanium 3LZ, Q8A.
10-11-2007, 03:57 PM
Understand this basic principle: a given engine, with a given airflow capability (displacement, heads, intake, etc.) will make a certain amount of torque, almost irregardless of what cam you put in it. Horsepower = torque*rpm/5252, always and forever, for every engine in the world.
What you are doing when you choose a cam is deciding where in the RPM band you are going to make your torque, and hence how much horsepower you will make. The higher the rpm where you make torque, the more horsepower you will make. Easy, right? Well, here comes the bad part: your average engine only has a power band, or efficiency band, that is about 3,500 rpm wide, give or take. So, if an engine runs really well at 6,000, it's going to need to be spinning at least 2,500 to get into the band where it starts to run well. When you choose a cam, you're just sliding that band up and down, and whatever you gain up top you inevitably lose at the bottom. This notion is what you will be negotiating when you talk to Greg.
10-11-2007, 05:26 PM
Z51
Greg would know! I also plan heads and cam down the road, but i gotta do headers first.
10-11-2007, 06:18 PM
LS6 Intake Mani
Ported TB
What say you....
Well the first ? is what is your current # now?Are you looking for brake horse power/torque or RWHP/Torque #?
The reason I asked is because depending on the your current # and close or far you are from 400+ hp/tq,you may beable to just get you present heads polished and ported and increase your air flow to get you to those #'s.Some rocker work and new valve's and you will be surprise how much more hp/tq you will get,It's alot cheaper also.Just another idea.
Changing your cam is a big decision,It will only help you if you use the vette for the right reason's,moving your power band up or down will only be applied on certian times,What I mean is,will you really use that higher or lower power that much and is it worth the money?Sure it will make your vette sound different and run alittle different but for the money I would try something else before a cam swap.But it's your time and money.If you decide to do a head and cam swap don't for get your check your lifter's to see if they will also work with your new combo.
10-11-2007, 08:17 PM
spam sniper
WoW, good posts everybody thanks!!
I'm looking for 400+ to the wheels As for my current #'s...?? I haven't been on a dyno yet, but with my mods thus far i'm predicting / expecting 300-320 rwhp. Hell I better be at that point with what I spent so far on mods!!
I'm turning to H/C cause its financially possible at this point, as FI will not be for a few years it looks like. Its easier to piece together than it is a blower kit or turbo kit, which i'm realizing now.
10-12-2007, 09:15 AM
Wrencher
400rwhp is easy these days. Back in the early days of the LS, 400 was the magic number. That was 1999. Now a heads/cam is in the 425-475 range typically. Sleepers can go in the 400-up area. We did one a few years back that had to look and sound stock. He made 392rwhp through manifolds and an automatic. His wife did'nt even know that anything was different. He said the extra hp was from a tune
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
'65 Seat Cover Installation
RSS Feed |
Tech and How-To Articles |
0 |
10-04-2007 01:05 AM |
