Unread 12-18-2007, 03:34 PM   #1
Anthony Caliendo
Anthony Caliendo has disabled reputation
Question 95 Headlight Problem
I have a 95 corvette and have been having problems with the headlight actuators running a couple of seconds after the headlights are up or down making a knocking sound. This problem started when my battery was dead and I hooked up the battery charger, I may have blown a relay or switch. Has anyone had this type of problem and what can be done to correct it?
Anthony Caliendo is offline   Reply With Quote
Unread 12-18-2007, 04:06 PM   #2
als2052
Road Trip!
als2052's Avatar
als2052 is on a distinguished road
Welcome to the site Anthony....please provide pics of your pride and joy. I am sure some of our resident experts will be chiming in within a short time to address your problem...
als2052 is offline   Reply With Quote
Unread 12-19-2007, 08:34 AM   #3
fletcher4u
fletcher4u has disabled reputation
YOUR ACTUATORS NEED TO BE REBILT THE KITS ARE LISTED IN THE ECKLERS CATALOG. ITS NOT ALL THAT HARD TO DO
fletcher4u is offline   Reply With Quote
Unread 12-19-2007, 09:26 AM   #4
AdvAutoBob
got nitrous?
AdvAutoBob's Avatar
AdvAutoBob is on a distinguished road
The drive pins in the actuator motor are bad, thus needing replacement. Common issue. We have the kits in stock to repair them.
One thing I've found... do BOTH sides at the same time. If the pins have deteriorated to the point of failure in one side, the other side isn't far behind.
Robert Williams
got nitrous? We do!
Advanced Automotive of Cape Coral
Specializing in American Performance featuring CORVETTE
(239)-573-9933
www.advancedautocc.com
AdvAutoBob is offline   Reply With Quote
Unread 12-19-2007, 10:47 AM   #5
shakedown067
Sinister C4
shakedown067's Avatar
shakedown067 is on a distinguished road
Yep, the bushings are toasted. I also recommend replacing the gears with the bronze units while you are in there. I just did mine on my 96 earlier this year. Not too hard of a job.
shakedown067 is offline   Reply With Quote
STS oil leak problem... Rich Z Maintenance, Mods, & Tips 23 10-13-2007 12:41 AM
Cracked Headlight - 2007 C6 C6 Corvette - SRQ Maintenance, Mods, & Tips 2 08-05-2007 12:48 PM
Passkey/vats problem Rocky Maintenance, Mods, & Tips 3 02-02-2007 10:22 PM
HVAC problem... Rich Z Maintenance, Mods, & Tips 8 10-03-2006 02:31 PM
I had a drug problem when I was young Nytro General BS forum 8 10-01-2006 10:19 PM
Page generated in 0.60303307 seconds with 11 queries
