Go Back   The ALL Florida Online Corvette Club > Classifieds and Commercial Sponsors > Classifieds - Corvettes, Parts & Accessories
Classifieds - Corvettes, Parts & Accessories Sales | Wanteds | Sources | Advice For Buying or Selling
Unread 08-07-2013, 02:46 PM   #1
XP Motorsports
XP MOTORSPORTS
XP Motorsports's Avatar
Name : XP Motorsports
XP Motorsports has disabled reputation
Default Formula 43 Wheels The NEW Standard in 3 Piece Wheels
NO NEED TO WAIT MONTHS FOR CUSTOM WHEELS
MADE IN THE USA
in
Livonia Michigan
Formula 43 modular wheel center sections use a Rotary Forged process that results in a superior tighter, circular grain structure. The rotary forged center section begins life as a cylinder of billet. The billet is then heated and placed into a die in the rotary forging machine. The die spins the billet at 300 RPM while the billet is pressed from above at a 5 degree angle. The material then flows in a circular pattern into the die. The new forging is then heat treated, quenched and aged to T6 standards. The end result is a rotary forged center section that has stiffer spoke dimensions, lighter weight and a quicker moment of inertia.
The Spin-Form process developed by Formula 43 is a specific method in spinning 6061 aluminum circular sheets into 2 piece rim-halves. The computer controlled German spinning machine uses four rollers to form the inner and outer rim-halves on tooling designed in the shape of each rim-half. The Formula 43 method is a three step process:
(1) spinning the part.
(2) heating and aging the 6061 rims to T6 condition and
(3) re-calibrating the rim-half after heat treating to ensure a very low run-out of the part.
Along with the Formula 43 process, several changes to the rims have been made to better fit and perform with today's modern racing and sports cars:
1. Improved safety bead on both inner and outer rims to ensure proper seating of the tire so that the tire will stay mounted to the rim in the event of impact or loss of air pressure.
2. Improved rim contour to help ease tire mounting and bead seating.
3. Added material in specific areas of the rim-half for additional strength and stiffness.
4. Drop center contour updated for proper TPMS fitment and installation without having to add additional brackets or modifications.
Used By many of the top Grand AM RACE TEAMS
Including
Stevenson Motorsports Camaro, Automatic Racing's BMW and Aston Martin & Others
Formula 43 Rad 10 18x11/18x13 Set of 4 05-13 Corvette ZO6/C6 Laguna Gray
RAD 10
Ten radial spokes are aligned with each lug pocket and each spoke has an opposing spoke resulting in maximum strength, minimal deflection and long service life. Forged center section and AL6061-T6 German Spin-Form modular rims standard
Package Includes
(2) Front 18x11 Rad 10
3 piece Wheels Correct Backspace C6/ZO6
Large Brake Kits Will Fit
(2) Rear 18x13 Rad 10
3 piece Wheels Correct Baclspace C6/ZO6
$3840 delivered lower US
http://www.xplosiveperformance.com/F...y-_p_3508.html
Formula 43 Rad 5 18x11/18x13 Set of 4 05-13 Corvette ZO6/C6
Traditional “Five-Spoke” design with a new 21st century look. Each side of the RAD 5 spokes feature our sculpting to reduce weight and also add additional dimensional definition to the wheel. An excellent choice for a wide range of applications. Forged center section and AL6061-T6 German “Spin-Form” modular and blind fastener technology standard.
Package Includes
(2) Front 18x11 Rad 5
Large Brake Kits will Fit
(2) Rear 18x13 Rad 5
http://www.xplosiveperformance.com/F...6-_p_3513.html
Formula 43 Rad 6 18x11/18x13 Set of 4 05-13 Corvette ZO6/C6
Split-Six Spoke design with a splayed “V” and large chamfers on each spoke. Each “V” is balanced with an opposing “V” keeping the wheel design symmetrical. An excellent choice for a wide range of applications. Forged center section and AL6061-T6 German “Spin-Form” modular rims and blind fastener technology standard.
Package Includes
(2) Front 18x11 Rad 6
(2) Rear 18x13 Rad 6
http://www.xplosiveperformance.com/F...6-_p_3518.html
Formulas 43
Any Style Wheel RAD 5,RAD 10, RAD 6, RAD 5S
any Standard Options
Package Includes
(2) Front 18x10
(2) Rear 19x12
$3890 delivered lower US
Order a set of wheels between now and August 31, 2013 and get a complete set front and rear Hawk Performance 1 piece Ceramic Brake Pads to keep those new wheel clean and get superior stop power
C6/ZO6 only
Other Width available
19's Available
See all the Options & Packages
http://www.xplosiveperformance.com/A...s_c_12292.html
Sales Dept
XP Motorsports
Xplosive Performance Inc.
640 Poyner Drive
Longwood, Fl 32750
888.493.8041
888.493.8041 fax
sales@xpmotorsports.com
AIM: CH3NO2fun
Skype: Xplosiveperf
Facebook Twitter www.xplosiveperformance.com
Members SEMA, SPC. NHRA, NASA, SCCA, IMSA,CHIN
XP Motorsports is offline   Reply With Quote
C5/C6/ZO6 Slotted Rotors & Hawk Brake Pad Packages XP Motorsports Classifieds - Corvettes, Parts & Accessories 0 10-21-2012 03:02 PM
Mike Rini of Pembroke Pines, FL Rich Z Board of Inquiry® 39 09-18-2006 11:03 PM
Page generated in 0.08737302 seconds with 11 queries
