Unread 04-19-2011, 01:15 PM   #1
Sub-Zero
Sub-Zero has disabled reputation
Default Boost Coming!
Well I didn't plan on doing anything but bolt-ons but I got a deal on a STS turbo setup. It won't be soon but I can't wait to see what it will do.
Sub-Zero is offline   Reply With Quote
Unread 04-19-2011, 03:36 PM   #2
Yeah man.... You've got the bug BAD!
Unread 04-19-2011, 04:42 PM   #3
Sub-Zero
$2,600. I couldn't pass it up
Unread 04-19-2011, 07:26 PM   #4
Can't say that I blame you. That is an incredible price!
If you don't mind a suggestion.... Get all the pipes Jet Hot coated. Inside and out. I don't know if STS made any improvements on the coating they used when I got my system, but the pipes are just mild steel, and the coating they used, well, it's obviously not the best in the world. There is some rusting evident. Also pull the housings off of the turbos and get them coated inside and out.
Unread 04-19-2011, 08:06 PM   #5
Sub-Zero
Thanks, all the piping will be re-coated and the turbos are at the turbo shop getting checked out and the will be jet coated. It was cheap because it needs the oil pumps, oil lines and misc. stuff. I will have about 5k installed in it.
Unread 04-19-2011, 08:26 PM   #6
I understand that the new systems come with two oil scavenge pumps now. When I got my system they use a single pump, which seems to work fine.
I assume the system is used then? Hopefully the turbos are OK. I recently had mine rebuilt as the impeller shafts had play in them. Plus I needed to go to larger housings with the new engine.
You'll enjoy the hell out of it when you get that installed in your car... Turbos give a real interesting surge of power when they spool up under load.
Unread 04-19-2011, 08:53 PM   #7
Sub-Zero
The turbos are getting rebuilt. Planned $650 for this. Everything will be like new when I install it. Planning just 6psi.
Unread 04-21-2011, 09:29 AM   #8
6psi is probably the highest you should go on the stock LS7. I think GM was trying to tell us something when they decided against using the LS7 block as the base for the LS9 engine and went with the LS3 block instead.
Still, 6psi will give you an acceptable amount of boost.
Unread 04-21-2011, 09:37 AM   #9
Sub-Zero
I agree. I will keep the boost low.
President Coming Back To South Florida RSS Feed Florida News Feeds 0 02-18-2011 06:30 PM
FDIC asks Bank of Florida-Southeast to boost capital RSS Feed Florida News Feeds 0 04-30-2010 09:00 PM
South Florida expects huge cash boost from Super Bowl RSS Feed Florida News Feeds 0 01-11-2010 08:40 AM
Florida Lottery mailing out coupons to boost sales RSS Feed Florida News Feeds 0 04-01-2009 07:04 AM
Florida looking for big boost from U.S. economic stimulus package RSS Feed Florida News Feeds 0 01-24-2009 08:10 AM
Page generated in 0.14230299 seconds with 11 queries
