Go Back   The ALL Florida Online Corvette Club > Florida Corvette Clubs > Suncoast Corvette Association
Suncoast Corvette Association Events and Happenings
Unread 01-30-2023, 06:50 PM   #1
cwbeachbum
cwbeachbum's Avatar
Name : Philip J. Adams
cwbeachbum is on a distinguished road
Default Need a reputable transmission shop I can trust!!
Does anyone know of a good corvette transmission repair shop in the tampa bay area that knows the workings of the C5 six speed tranny and linkage. Have a problem with the shifter popping out of first gear and hard to get into reverse. Years ago a non corvette tranny guy resealed the tranny and when I picked it up it popped out of first gear and reverse. I rotated the linkage bar clockwise and was able to get it to stay in first but still popped out of reverse. Drove like this for ten years and finally had a clutch replaced and the problem is worse. I can turn the linkage bar clockwise like before and tighten the bolt on the clamp and get it to stay in first gear but now cant get it into reverse. You can hear the gears touching but wont engage. The shop that replaced the clutch thinks the couplers on the end of the linkage bar where bent by the non corvette tranny guy making the bar shorter so he had to pull the shifter box as far back as possible to get to work. I purchased a replacement linkage bar but now can't find a tranny shop to just replace the linkage bar. They just want to rebuild the tranny. It shifts fine from one to six once I get it onto first gear so hoping its just the rod and not the tranny. Thanks for any input/suggestions.
cwbeachbum is offline   Reply With Quote
Unread 01-30-2023, 11:33 PM   #2
I can't vouch for them personally but I have watched a bunch of videos done by them, and purchased parts from them to fix my own driver's seat (one of these days). The parts they sold me seem to be top notch with the machining. They seem competent from what I have seen, but I suggest you talk with them yourself to see if they can help you.
https://www.corvettepartscenter.com/
Good luck!
Unread 02-04-2023, 03:37 PM   #3
cwbeachbum
cwbeachbum's Avatar
Default Tranny corvette shop
Thanks! I think I will check them out.
Unread 02-05-2023, 11:59 AM   #4
Let us know how it turns out, please.
Unread 02-05-2023, 12:19 PM   #5
cwbeachbum
cwbeachbum's Avatar
Default Transmission shop?
Will do, Thanks.
Transmission jack confusion Rich Z Maintenance, Mods, & Tips 11 12-01-2015 09:40 AM
Our Annual List Of Where To Get Your Corvette Fixed RSS Feed Tech and How-To Articles 1 08-06-2010 02:56 PM
C3 Transmission Swap - Grabbin' New Gears RSS Feed Tech and How-To Articles 0 10-01-2009 09:01 PM
JOHN TSIKOURIS - GOODFELLAS TRANSMISSIONS MadDogLou Board of Inquiry® 20 11-12-2007 09:25 AM
Am going to look at........ Kap142 Classifieds - Corvettes, Parts & Accessories 11 12-19-2006 07:17 AM
Page generated in 0.06531692 seconds with 11 queries
