1ragtop
NEW FULLY ASSEMBLED NEVER USED JUST BOUGHT THIS WEEK.
DescriptionRICE IS CHEAPER THAN NEW BY $34 AND ITS ASSEMBLED NEVER USED.NO TAX.
This foot pedal operated hydraulic motocycle lift stands are the perfect solution for the biker who does not have compressed air in his shop or garage. Lift up to 1000lb. Motorcycle simply by operating the hydraulic lift pedal. Includes rear drop panel and rubber padded wheel vice.
This motorcycle lift table is high quality, hydraulic operated lift being offered now at this great introductory price. This lift will accommodate almost any motorcycle on the market up to 1000lb capacity without the need for a air compressor. These hydraulic motorcycle lift stands will raise your motorcycle for service, maintenance, cleaning or bike shows by the simply pumping on the lift pedal.
These hydraulic motorcycle lift stands have an operating height from 10"(205mm) to 31"(780mm) high. The platform is 83" long by 13-1/2" wide and it includes a 24" long loading ramp which brings the total length of the motorcycle lift to 107 inches. All TMS motorcycle lifts come standard with an oversize front tire wheel clamp and rear drop out panel for servicing the rear tire. This hydraulic motorcycle lift stand has rear wheels allowing the lift to be moved around the shop. The TMS hydraulic motorcycle lift has a powder coated glossy finish with a diamond plate design traction surface for superior traction when loading and unloading your bike.Some other features include a front wheel clamp , a removable safety locking bar, attached tie down loops and lock down screws to prevent movement of the lift.
Features:
No air compressor needed
Hydraulic foot pedal allows a hands free operation without bending over
Deluxe hydraulic ram will easily lift motorcycles up to 1000 lbs
Motorcycle lift includes an oversize front tire clamp for extra security
Includes 24" long removable rear loading ramp
Rubber wheels makes it easy to roll lift around the shop
Rear drop out panel for service to rear tire, sprockets or drive shaft
13-1/2" x 19-1/2" rear tire drop panel is standard with TMS motorcycle lift units
Powder coated glossy black finish with built in checker diamond plate design for traction
11 gauge steel construction
Features:
