XP Motorsports
XP MOTORSPORTS
Chevrolet Corvette C6 / C6 Z06 2005-Up GTC 500 Adjustable Rear Wing
http://www.xplosiveperformance.com/C...ng_p_2974.html#
Spanning 70 inches, the GTC-500 Carbon Fiber Adjustable Wing is the largest wing available in APR's catalog. With its optimized 3D airfoil shape, the GTC-500 is perfect for high speed touring applications and supplies an ample amount of downforce without causing excess drag.
SCCA STO Class Approved.
2006-Up Chevrolet Corvette (C6 Z06 / Grand Sport only) Version II
http://www.xplosiveperformance.com/2...II_p_3077.html
Carbon Fiber. 2” extension (center), 3" extension (next to air ducts). SCCA STO Class Approved.
Underbody components such as front air dams, undertrays, and rear diffusers are essential for maximizing aerodynamic performance. The APR Performance Front Air Dam integrates with the factory front bumper to:
- Reduce lift.
- Increase front-end stability.
- Improve high-speed cornering grip
This Front Air Dam also utilizes a built-in aerodynamic splitter design that creates a high-pressure region of air atop the protruding surface, further reducing lift and increasing net downforce.
Integral to the Front Air Dam is a lower undertray design that allows for smoother underbody air flow. Cut out sections of the lower undertray design also retain the functionality of the factory brake system's cooling ducts.
2006-Up Chevrolet Corvette C6 (Z06 only) Side Rocker Extensions
http://www.xplosiveperformance.com/2...s-_p_2981.html
APR Side Rocker Extensions are the next step to help aerodynamically tune the handling of a car. Made of lightweight and durable carbon fiber composites, APR Side Rocker Extensions help reduce lift at high speeds by preventing air at the sides of the car from rolling underneath the car. The reduced lift helps to stabilize the car during high-speed cornering and helps to increase traction for faster lap times.
- Reduce lift.
Features: Carbon Fiber Construction
All APR Side Rocker Extensions are made in carbon fiber composites for lightweight and high strength.
Vehicle Specific Design
APR Side Rocker Extensions are designed and manufactured for specific vehicles for perfect fitment.
Mounting Hardware Included
Screws, nuts, and washers are included to allow you to install the APR Side Rocker Extensions to your car.
2005-Up Chevrolet Corvette C6 / C6 Z06 Diffuser Carbon Fiber w/ reverse LED (leaf spring system only)
http://www.xplosiveperformance.com/2...ly_p_2979.html
Diffusers work in conjunction with other aerodynamic components of a car to help produce downforce. Because a car displaces air as it moves forward, the air molecules in the rear of the car get disrupted causing a vacuum of low pressure air.
To help channel the high speed air flow coming from underneath the car, diffusers redirects the high speed air flow to transition smoothly transition into the low pressure vacuum in the rear. This encourages a smoother flowing air flow underneath the car and allows better performance from other aerodynamic components such as aerodynamic wings.
2005-Up Chevrolet Corvette C6 / C6 Z06 Diffuser Carbon Fiber w/ reverse LED (coil-over system only)
