Well, since I had a lift installed in the garage, I really don't think I'll need these any longer. Only used once and been sitting out in the shed since then.
These are the 67" models that list for something like $250.00 per pair. The place I got them from charges $46 shipping as well.
I'll let them go for $100, but the catch is that you will have to pick them up here in north Florida.
Here's some pics I took when I first got them:
Here's a pic showing the bottom of one of them.
Bottom is closed off so there will be excellent surface area on the ground. Weight limit is 1200 to 1500 lbs per ramp (paperwork says 1200, ramp itself says 1500 - probably not an issue with a Corvette, though). There wasn't any problem with clearance when I pulled the rear of my C5Z onto them. They are 67 inches long. Width is 14 inches, and they will raise the car just over 10 inches.
Pretty lightweight, too, considering. Surface is a very rough almost crinkle finish, so there won't be any slipping, I would imagine.
Here's a link to a page that sells them retail -> http://www.discountramps.com/low_profile_car_ramp.htm
