Unread 05-15-2006, 09:32 PM   #1
john s.
john s. is on a distinguished road
Default I need help. with the oil dipstick tube
I am putting my z06 back to stock and I need to find out how the oil dipstick tube goes. I cant remember where it went or how it was bolted down with the stock manifold, If anyone can shhot me a picture of their stock manifold with the dipstick and where and how its bolted I would appreciate the hell out of it. My neighbor is dying to buy my car so I need to get it finished soon. Please help! thanks
john s. is offline   Reply With Quote
Unread 05-15-2006, 10:47 PM   #2
If I remember tomorrow, I will take a couple of pics for you. Been meaning to take pics of my headers anyway, so all I need is an excuse to make the time to do it.
If you don't see pics here by tomorrow early afternoon, send me a reminder.
Unread 05-15-2006, 11:24 PM   #3
SteveGel
SteveGel's Avatar
SteveGel has disabled reputation
Inspect the O-ring seal for cuts or damage. If the oil level indicator tube O-ring seal is not cut or damaged, it may be reused.
Lubricate the O-ring seal with clean engine oil.
Install the O-ring seal onto the oil level indicator tube.
Install the oil level indicator tube into the engine block and rotate into proper position.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the tube bolt to the right cylinder head. Tighten
Tighten the oil level indicator tube bolt to 25 N·m (18 lb ft).
Install the oil level indicator into the tube.
SteveGel is offline   Reply With Quote
Unread 05-16-2006, 01:11 AM   #4
FourG63 97GST
FourG63 97GST's Avatar
FourG63 97GST is on a distinguished road
umm so what aftermarket parts you have left
-Agim
FourG63 97GST is offline   Reply With Quote
Unread 05-16-2006, 07:00 AM   #5
john s.
just a bpp vortex rammer intake with precut radiator shroud. its in the classified section
Unread 05-16-2006, 07:00 AM   #6
john s.
Notice
Thanks alot! that pretty much shows what i needed to know. It looks I changed tubes out with my lgm pro long tubes, that would explain why it isnt fitting now. I need to find my stock one or buy a new one I guess. Thanks alot.
Unread 05-16-2006, 07:01 AM   #7
SteveGel
SteveGel's Avatar
No problem, I think i have a brand one sitting somewhere.
Unread 05-16-2006, 07:09 AM   #8
john s.
If you've got one you want to sell ill buy if from you if you can ship it ups ground today so it gets here tomorrow. i can paypal you the money asap. let me know. thanks
[TIP] Resetting The Oil Life Monitor Rich Z Maintenance, Mods, & Tips 8 05-01-2006 10:41 AM
Page generated in 0.09709811 seconds with 10 queries
