Go Back   The ALL Florida Online Corvette Club > General Corvette Forums > Z06Fever!
Z06Fever! Well, why not? Having one of these toys is definitely an illness for which there is no cure, so let's talk about this specific malady.
Unread 05-27-2010, 05:10 AM   #1
Disturbed Customs
Disturbed Customs's Avatar
Disturbed Customs has disabled reputation
Default RPE650 Z06 Naturally-Aspirated LS7 Performance Upgrade
Open up your LS7 with a pair of high flow cylinder heads, a custom spec camshaft, long tube headers and a stainless steel exhaust for an astonishing gain of over 150 horsepower!
657 HP
593 TQ
The RPE650 Z06 Upgrade Includes;
• High Flow Cylinder Heads w/ Valve Job, Valves & Springs
• RevXtreme Custom Grind Camshaft
• High Performance Head gaskets & Head Bolts
• High Flow Cold Air Induction System w/ Larger MAF Sensor
• RevXtreme Ported Intake Manifold
• Ported & Polished Throttle Body
• Stainless Steel Long Tube Headers
• Stainless Steel 3" Exhaust System
• 160 Degree Thermostat
• RevXtreme Badging
• All Necessary Gaskets, Fluids & Hardware
• Professional Installation, Dyno Tuning & Road Testing
• Serial-Numbered Plaque in Interior & Engine Compartment
• Optional One Year Limited Warranty
Call RevXtreme Performance & Engineering at (941) 755-3535 for More Information
RevXtreme, RPE, RevXtreme Performance Closed Down.
PKG is no longer Available through them.
Tracy the old owner came up with the package (well copied it from Hennessey and it has died off. Do your research on Tracy and RevXtreme you will find out more than you want to know.
Thanks
Disturbed Customs
Disturbed Customs is offline   Reply With Quote
Unread 08-29-2010, 12:00 AM   #2
intheboost
intheboost has disabled reputation
Will call you next week. Curious what a head/cam/tune only package costs.
intheboost is offline   Reply With Quote
Unread 08-29-2010, 08:28 AM   #3
ironhorse
Road Warrior
ironhorse's Avatar
ironhorse is on a distinguished road
657 HP
593 TQ
• RevXtreme Badging
these numbers are at the cranK?...Please post dyno sheets...
Thanks,
JT
ironhorse is offline   Reply With Quote
Chevy’s Z06 is the perfect sledgehammer Curacao General Corvette Discussions 1 01-14-2010 05:20 PM
C6 Z06 - Maximum Acceleration RSS Feed Tech and How-To Articles 0 02-07-2008 01:01 PM
C5Z vs. C6Z Zach Z06Fever! 4 05-14-2006 08:27 PM
Page generated in 0.23444700 seconds with 10 queries
